Have you exposed the 1/2" alky back to its Tee connection with the main water service? If so, you could replace with a single length of 1/2".
If its not totally exposed or accessible then cut the pipe and use a new length from the repair location to wherever you want - that way there's only one repair fitting below ground.
Take an off-cut of the 1/2" to the plumbing suppliers and tell them your story. You will need a straight coupler.
