joining 6mm cable
30 Jun 2005
Hi Guys,
I have a length of 6mm cable from a 32a mcb in consumer which i want to take to an outside switch which will then power the electrics to my garage via swa. The problem is that my 6mm cable is about 3 foot to short for what i need to do so what would be the best way to extend this cable? Could i crimp it to a new piece of 6mm or would it be best to use a 40a jb?
Ideal solution - new run of cable.
Junction box is fine, but needs to be accessable.
Through crimping as you have just described needs a yellow crimp, applied properly, with proper crimping tool and then protected with heat shrink sleeve, or AT THE VERY LEAST, self amalgamating tape.
Spark123 Posted: Mon Feb 11, 2008 9:10 pm Post Subject:
Where is the joint going to be?
Thanks spark 123. the joint will be on the inside of the outside wall and i was hoping to bury it in the wall so i guess a jb is out of the question
Click-Sure Posted: Mon Feb 11, 2008 9:45 pm Post Subject:
Thanks clicksure but a new piece of cable is not an option as it runs from the front of the house to the back. I do have ratchet crimpers but only have blue and red crimps and i think my crimpers would only accept 1mm, 2.5mm and 4mm ?
