I am planning to lay a new flight of stair carpets. however, on the top landing of stairs, I have laid laminate floor. I am thinking of following options:
1) lay carpets from bottom all the way up to the riser (beneath the first nose from the top landing), while the entire landing is having laminate floor.
With this option, what edge trim can I use? I have read in another post that 'L' shape trim can be used, note sure what it looks like and how to use it?
2) lay carpets from bottom all the way up to the riser and, continue carpet on to the landing (may be 1 inch in the landing) and make a join in the landing with laminate floor.
With this option, I can use a connecter 'from laminate to carpet', but what is the safe distance for carpet to be in landing to make this type of transition from carpet to laminate. is 1 inch enough?
I appreciate for any help you may offer.
Many thanks & regards.
