- Joined
- 25 Mar 2024
- Messages
- 5
- Reaction score
- 0
- Country
Hi guys,
I'm unsure whether this should be in this section or the building section? Apologies if I've got the wrong section!
I am in the process of renovating my bungalow which is removing 3x chimney breasts (2 of which are adjoining one another) and also a small box room.
I've had a structural engineer around but they've advised that what I'm asking is out of their scope... so I've contacted Building Control but I'm not sure if it'll be in their scope either but hoping for some advice from some of the wonderful people on here!
I've uploaded a folder on Dropbox (due to screenshot file sizes being large) which shows my floor plan and also annotated the chimneys breasts and box room walls to be removed (I should highlight - it's the ground floor chimney breasts only as loft breasts and roof stacks have been removed previously before we bought the house). There is also a quick Solidworks sketch showing the removal of the small room wall which is perpendicular to the joists (joists running from front to rear or property).
Dropbox link here: Dropbox - 3x joists
Basically, my concern is that I've propped up the ceiling and removed the box room walls and there are 3 joists which are running from the front to the rear and are unsupported the whole way. There were about 6 or 7 joists which were supported above the (now-removed) box room wall and also on top of the 'bedroom' and 'lounge' (as per the floor plan) but when I've removed the box room wall - most of them are supported by the walls of the 'bedroom' and 'lounge'.
The 3 joists which are running along the hallway would be completely unsupported if I removed the props. So, I was given a bit of advice that I can make a 90mm cut into the 3 unsupported joists then put two 2x8's in that cut-space secured to the joists nearest to the 3 unsupported joists with double joist hangers, then I can secure the 3 unsupported joists to those 2x8s's, again with joist hangers - and this would then support the 3 joists by using the joists nearest to them, which are bearing on the 'bedroom' and 'lounge' walls.
I hope this makes sense and the Dropbox link makes it easy to understand what I'm saying. I'm just wondering if anyone has experience of this and if it's all OK to proceed with as I don't want to go cutting 90mm spaces in the joists if not!
Cheers, e_p
Cheers, e_p
