I've started to take a look at how I'm going to lay out my floor and I'm confused on something. Not hard to be honest
Basically If I lay board one and cut off 1/3rd at the bottom of this board to start row two I'm then left with a sawn end with no click system to use on row two. I take it you just 'but' boards like these boards together?
The reason I ask is that if that's the case my cuts are going to have to be perfect to get a neat square finish. Which cutting by hand doesn't seem to be that easy.......
The other way appears to be leaving the click system in place at the top or bottom of each board, but that makes it a nightmare to click in lengthways?
I'm probably confusing myself with this.......
