Good day all,
I have a large cold water storage tank I need to replace on top of a block of four flats feeding cylinders and down service to all flats. Currently the mains feed to the ball valve comes up out of the floor in lead pipe and this is where I will need to connect onto it and run new copper the rest if the way to the new tank ball valve.
My problem is that this all needs to be done in a day and until the old tank is out I can't really see the size of the lead or what sort if state it is in. However, by looking under the current tank I can see that the lead appears to be about 40mm thick. For smaller lead pipe in the past, I have used a leadloc to join on but they only seem to make those to connect onto the lead equivalent of 1/2 inch and 3/4 inch.
I need to have a selection of fittings with me ready to try and make the connection as I won't have time on the day to drive around the merchants with a lump of lead trying to get something to fit it.
Any suggestions?
Any suggestions?
