I’ve been reading another current post on “coax cable for sky?” and I need some advice about joining satelite cable runs. My current situation is:
Dish high up chimney stack. ‘Shotgun’ cable drops down chimney stack and enters building at high-level through the gable wall into the attic where it runs across to the other side of the house (detached double-fronted Victorian) and then out through the other gable wall. It then drops down two floors to ground level where it enters the building again and into the Sky+ box and flatscreen telly. I’ve got other separate TV’s scattered about the house but all are on conventional aerial for Freeview.
I plan to move the Sky+HD box and it’s flatscreen telly to the other side of the house so need to extend it’s ‘shotgun’ cable to reach.
Ideally, I’d like to cut the ‘shotgun’ cable (from the dish) in the attic and connect it with a new length of similar cable which could be routed to the new position of the Sky+ box. Is it acceptable to JOIN this type of cable, say with F connectors, and not compromise the signal?
The now redundant length of cable will be left in situ. Would you recommend the above join (in the attic) be via some sort of splitter ... so that the ‘old’ cable route could remain viable so that the Sky+ box and telly could be moved back ... maybe after Mrs Symptom’s change of mind about the new sitting room?
If the above plan is fine perhaps you could post a shopping list of bits I’d need.
Thanks in anticipation of your advice.
