I've to join a 22mm Speedfit recirculating DHW loop under the floor to 14 year old 15mm Hep20, rising through the floor, to the various hot taps.
Is it appropriate to do this with Speedfit branch reducing Ts with appropriate inserts in all the pipe or should I use compression fittings. The former will be much easier in the confined space.
Helpful advice gratefully receied.
