Hi all ,
I am about to commence drylining /plasterboarding my garage ceiling I've insulated it and put up a vapour barrier and now am ready to fix the boards (whatever they are called !!) to the ceiling .
reading up tonight i've come across a post that totally confused me .
It states that when just filling the joins in the plasterboard (using tapered edge) to butt the boards together with a V shape to allow the jointing compound to have more to adhere to .
is this correct I thought the boards were supposed to go together like a french cleat to give them support and a smaller join ?
also do i fill the V joint (if thats correct then put the adhesive jointing tape on or put the tape on first then fill the joint gap .
lastly my garage is 2.36m wide by 7 m but the ceiling joists run perpendicular to the garage so would i be better fitting the boards(2400x1200) in staggered joints length-ways or parallel to the joists making sure that the joints are on joist centres (the latter way would be easier but one wall is irregular and I would have to scribe each board to fit) is there an easy way to achieve this by leaving a gap at the bad wall side as I'm going to build a stud wall up to that height which will hide the gap .
Apologies for all the questions but i want to get it right first time
Many Thanks in advance for any advice given
Glenn
Glenn
