I'm adding another section to my garage side by side and am unable to figure out how to join the trusses to get a trough or gutter for roof water both sides will be tiled think of ^^ and you will see the problem
I sse no problem ...only a lovely tapered gutter,that I could cover with lead...plumbers used to do that But I guess you`ll do it with felt. Do a bit of origami and you`ll see that the gutter has to be wider @ the end opposite the outlet..to allow it to fall to said outlet. Trusses? cut and pitch the new section.
