hey there
at work we have jus got an new extraction system and to be able to get enough power to the control pannel and motor i had to cut the 35mm S.W.A cable that feeds the nearest distribution board in half,then connect them back together through large terminals.then adding another 16mm s.w.a cable to each phase in the terminals which obviously conects to its own separte box with an isolator and big enough MCB the extraction now works correctly!
My problem is i dont feel that the connections through the terminals is strong enough because 35mm s.w.a cable is tough stuff and the terminals look like they could pop off the din rail anytime!
i was wondering if there was a standard way of doing this which is safe and realiable??
Any help would be much appreciated
cheers Padsterlad!
cheers Padsterlad!
