Hi All
Had a bit of an accident yesterday, drilled through a main power cable, blew the fuse at the main fuse box.
Question
I rewired the fuse in the main fuse box (15 amp) Then i chiseled out the wall to find out the damage done to the wire when i drilled through the wall, i need to replace a section of cable from the point i damaged to the socket it runs to, if i can do this what would be the best thing to use, a junction box, or connecting blocks.
Why i am asking this is that to trace the wire all the way back to the junction box it is connected to, i would have to chisel out the wall for about 4 feet, then lift the t & G floor boards in my daughters bedroom.
I hope i can connect the cable in one of the two ways that i have suggested, or it looks like a long job.
Question
