Hi folks
I ve got 2 kitchen base units back to back as an island in my workshop. I am fitting 2 work tops back to back on top of the units. I am going to use biscuits and work top bolts underneath to pull the join together as is usually done.
The problem I have is routing a straight edge so the join is tight. It's ok vertically but there's a slight gap which I doubt the clamps will pull together.
The join length is 1.5 metres long. I ve used a long spirit level a a straight edge to guide the router rolling it over so if there's and bowing it should match. Basically I think I need a better straight edge.
Any suggestions ?
Any suggestions ?
