- Joined
- 30 Sep 2004
- Messages
- 8
- Reaction score
- 0
- Country
theres is a 3o amp joint box in my kitchen wall joining ring main ive red thats bad practice will it be alright its been there 4 yrs
Damocles said:How did you find it? All junctions must be accesible. Sounds like you have just succesfully accessed it.
no was the joint box dangerous under the plasterandrew2022 said:u mite need access to it and not kno were it was
dangermouse said:wot would of happened had i not noticed it
Did you two have the same English teacher at school?andrew2022 said:u mite need access to it and not kno were it was
Damocles said:If I was re-doing my kitchen I would not bury a box unless I had no choice.
dingbat said:Damocles said:If I was re-doing my kitchen I would not bury a box unless I had no choice.
It is, quite simply, contrary to the wiring regulations to have inaccessible junction boxes. Reg 526-04-01 states;
Except for the following, every connection and joint should be accessible for inspection, testing and maintenance:
'the following' includes compound filled, encapsulated, welded, soldered, brazed and compression joints. Screw connections are notably absent and in the eyes of the NICEIC even junction boxes under removable floorboards are considered inaccessible. Whether or not that is too restrictive in practice is debatable but as far as giving DIY advice is concerned there is no choice when it comes to burying JB's in plaster.
