Hi there
I have masonry joist hangers installed into brickwork. The mortar joint was cut out and hangers inserted then filled back in with mortar. I'm a bit weary of using nails for noggings and the hanger itself as I don't want the hammering to disturb the mortar.
I'm being told that you can't use screws. Is this true. The joists span 2 meters and are 50mm x150mm.
Thanks in advance, Neil
