After pulling down plaster and lath from the kitchen ceiling, I noticed that a 7x3 inch joist isn't attached to the supporting wall at one end. Pulling down more plaster revealed a chimney hole that had been blocked off and hidden by plasterboard and also two other 7x2 joists that are connected to the first 7x3 joist.
Obviously the joists should be connected to the supporting wall.How is the best way to support the joists and chimney above?
The green joists are the problem ones and must have been like this for 25 years, I will try and post a photo later.
Thanks for any advice.
Daz
Daz
