I've got, above one of my rooms, a ceiling constructed of plasterboard on horizontal joists, and above that, 'attic' space, with an A-shaped roof, with roof slates to the outside. The 'attic' space is obviously not designated as such, as there's no hatch access to it.
If access were ever required to this roof space, how would I determine if the joist/plasterboard combination is safe to walk/crawl upon?
The room is 17ft x 20ft, with the joists apparently going in the direction of the 17ft span. They appear to be spaced at 20 inch centres.
Is there some reference somewhere, if I get the joist size, I can calculate a maximum load based on this and the span, or is it a moot point? Is it likely that the construction can be assumed to be safe for walking upon, since (I assume) the builders are likely to have negotiated it at some point.....? House is approx 6 years old, if that has any bearing (!) on the issue.
Regards, Graham
Regards, Graham
