Last night I tried to jump start a 1998 Ford Fiesta from my 1999 Ford Puma. I assume the problem is the battery as there is NO response from the ignition, not even a cough. So, time to jump - Easy, right? I encountered problems and aborted for fear of causing untold damage, hopefully you guys can help me find out what went wrong (if anything)
So here’s what I did
- Opened both bonnets
- Connected the Red cable to the positive on the dead battery
- Connected the other end to the Positive on the Good Battery
- Connected the Black cable to the Negative on the Good Battery
- Clipped the other end to a metal part of the engine block.
- Started the Puma and left it for 5/6 minutes
- Tried the Fiesta
And here’s what happened
- As I connected the last step (Black cable to the Engine Block) there was a bright spark (more or a clap) as it touched.
- The central locking activated
- After waiting for 5 minutes with the Puma running I tried the ignition on the Fiesta. The engine cranked once and the was another clap from the engine block, this time it was brighter and louder
- All the dials on the dash stuck at full, and the petrol registered at half full (This is with the keys out)
- A spark and a click occurred roughly every 30 seconds on the fiestas Engine Block
With this I decided to switch off the Puma and abort, taking all the cables off leaving the one clipped to the Engine last as it looked a bit angry. The dials (the last time I checked) are still stuck on full and there is again no response from turning the Key.
Any ideas on what happened? I can’t find anything like it elsewhere on the web.
Thanks!
- Tried the Fiesta
Thanks!
