Hello,
I have spent a very long time refurbishing my douglas fir herring bone parquet floor throughout the house. Its all patched, filled and sanded. I put on Juncker Pro Seal to emphasise the natural colours (solvent based) and then followed that with HP Sport Lacquer semi gloss (water based).
My problem is that the laquer is not taking very well to the now sealed wood. At a glance it looks fantastic but on closer inspection you can see patches where the lacquer has sort of beaded and is not provided a continuous cover. A lot of it has a dimpled texture like an orange peel and some of it just seems to have parted to reveall small areas of bare wood again. I'm guessing this is because i've put a water based product over a solvent based product, however, this is what the local specialist recommended (and some websites).
So, the question is what do i do?!
I can't sand i back again because i would be sanding off all the tongues & grooves! Do i just keep applying coats? I'm still awaiting a reply from my local specialist.
Any bright ideas would be very welcome!
Thanks.
Thanks.
