Junction box cable capacity
31 Jan 2013
Owing to a 'slight accident' while in the loft, I smashed a junction box on the lighting circuit feeding the floor below, so I bought a new one of a well-known brand. This was advertised specifically as a 5A 4-terminal lighting junction box.
The damaged box was rated for 5A and had 4 x 1.0mm cables: feed loop in, feed loop out, switch cable, light-fitting cable. Consequently 3 of the four terminals (L,N,E) each had 3 cable cores, the 4th terminal having just 2 cores. Seems quite normal to me.
Curiously though the new box was labelled for two x 1.5mm cores only. I tried it with 3 x 1.00mm and they did fit enough to get the grub screw to engage, but not very far. I was not happy with the result, so I have replaced it with a larger 20A box instead. Bigger terminals, got the 3 cores in easily, much better grip, so happy with the result.
But....even the 20A box was also marked as two x 1.5mm cores only. What is the point of a 4-terminal box, especially one sold specifically for lighting circuits, if the terminals are sized only for two cores? Or am I misunderstanding something here???
It probably differs from make to make, but I have found the so-called 5 amp junction box to be useless, and always use a 20 amp junction box for lighting.
A lot of the spiel about what can be put into a junction box is often rubbish.
That said, JBs do vary a lot depending on the make.
I once bought a cheap unbranded 30 amp junction box (3 terminals) which was usless for what I wanted as the terminals were so tiny. In the end I used it for lighting cables.
Hager junction boxes are usually the best, though some years ago they went through a bad period where the screws just broke the ends of the wires off far too easily. That seems to be resolved now.
I sympathise/empathise with all of that. The Hagar issue took a lot by surprise.
I will say that for a long time I've been thinking JB terminals are smaller than they used to be until I recently did some fault finding in a 1950's house with PVC/PVC cable where 5A JB's had been used for power circuits with 2 or 3 7/0.029" cables. Now I know JB terminals are smaller than they used to be.
Anyone remember the JB's with the SRBP insert with the brass contacts passing through 2 slots?
MK 1131 are the only ones I use for lighting circuits as it is so easy to wire them up logically
TBH I've always found them to be a pita having to run the wires right round the outside. But aren't they discontinued?
https://www.tlc-direct.co.uk/Products/ASJ804.html
I just use these now.
no still available but they have changed colour, still makes them easier to spot in a loft
https://www.tlc-direct.co.uk/Products/MK1131W.html
Ah, OK thanks for that, A little while ago they were spec'd for a job but came up as 'no longer available'. Maybe it was just the brown version. Luckily the work we were doing threw a couple spare so the problem went away.
Still doesn't change the fact I find having to run wires round the box fiddly:unsure:
