Hi All
A customer has requested an outside up/down light be installed to the front of a building to replace an old existing bulkhead. The light is currently positioned approx 4 metres high and the supply cable is 1.5mm T&E clipped direct.
They do not want brickwork to be drilled to allow cable access to feed behind the light. Is there a junction box available that is strong enough to support a light that weighs 0.75kg, in order to make the connections for the light in the junction box which would allow the T&E to be terminated into the box by a suitable gland?
Many thanks in advance for any help you can offer.
Mike
Mike
