junction box
i,ll stick with the ones that are accessible no confusion then.
I'm not sure what you mean by that. Whether or not any junction box is accessible obviously depends on where you install it, regardless of which product you use. Do you perhaps mean that you're going to install in an accessible location?
Kind Regards, John.
i,m going to position above a downlighter so that it can be pulled down for testing/access/faults etc i.e not the so called "maintenance free" ones
Thanks for clarifying. In that case, as you probably realise, you need to use the Ashley J501 suggested by holmslaw (or something similar) which has cable clamps in it. Because they have no cable clamps, any 'standard junction' box has to be screwed to something (and the cables clipped to something), which obviously would prevent it being 'pulled down'.
Kind Regards, John.
