I don't know which Part of the regulations these changes come under but I'm aware the 2022 regs now stipulate safety glass is used in 'critical locations' e.g. doors and windows within 800mm of the floor. Similarly some changes on ventilation - trickle vents, etc.
I am mid-way through re-building an old detached hot-house as a sort of conservatory/garden room/fancy shed - a new super-structure on top of dwarf brick walls. I haven't yet ordered windows and am not sure if this means I now have to up my spec. The build was already in progress prior to June and is renovating an existing, unheated structure - I don't know if any of these things matter?
I did come across this page discussing exemptions https://www.planningportal.co.uk/ap...ulations/exemptions-from-building-regulations and it seems specifically the "class 6 small detached buildings" might apply here. That would seem to indicate that other than parts P and L (if applicable) I am exempt (https://www.legislation.gov.uk/uksi/2010/2214/schedule/2/part/6):
Does this seem reasonable? My building footprint is almost exactly 5x3m so the floor area would be a trifle under 15m2 (490x285 I think).
(my emphasis in red)Small detached buildings
1. A detached single storey building, having a floor area which does not exceed 30m2, which contains no sleeping accommodation and is a building—
(a)no point of which is less than one metre from the boundary of its curtilage; or
(b)which is constructed substantially of non-combustible material.
2. A detached building designed and intended to shelter people from the effects of nuclear, chemical or conventional weapons, and not used for any other purpose, if—
(a)its floor area does not exceed 30m2; and
(b)the excavation for the building is no closer to any exposed part of another building or structure than a distance equal to the depth of the excavation plus one metre.
3. A detached building, having a floor area which does not exceed 15m2, which contains no sleeping accommodation.
