just moved in and need to turn off hot water
D shuts off HW, A will probably go to a shower, the rest are for CH.
thanks for the reply :)
I thought that the hot water was drained from the top of the tank ?
Valve D pipes off the bottom ..are you sure thats where my hot water and shower would come from
BTw I do have a gravity fed shower
Can anybody tell me what the other pipe above A will supply ?
thanks
Lee
Pipe above A is the HW supply to the whole house, valve D is on the CW supply pipe to the cylinder which enters at the bottom of the cylinder & pushes the HW out of the top based on the fact hot water rises.
When you shut of the HW you don't actually drain the cylinder you just stop the water flowing through it, even when the water stops you will always have a cylinder full of residual water until you either drain off from the drain off valve on the elbow or syphon it off.
If pipe A is going to your shower the you do have a gravity fed shower & your CH system is a Y plan.
thanks I understand this much better now.
So can I ask how come the central heating seems to feed from the bottom of the tank ??
Also do you have any idea what that pipe is half way up the cylinder ?
thanks for all your help
The pipe half way up on the left side is the flow, if you follow the pipe back it goes to a 3 port valve (the bit with the silver box marked Honeywell), this is the bit that gives you CH & HW or CH or HW only. The pipe on the bottom is the return these feed the coil inside the cylinder which in turn heats the water.
Hello leebarlow
Point D is where you can turn off the hot water as this pipe is feeding the cyclinder from the tank. Just open up the various hot water taps in the house and drain the water down. The water is drained down from the pipes leading to the hot water taps and the top of the cyclinder.
The central heating heating feeds from the bottom of the tank as hot water is primary and central heating is secondary.
Hope i've explained it okay :)
P.s. may be worthwhile installing 2 isolating/ service valves on the cold and hot water pipes to the bath in case you want to change the taps or have problems in the future
