Not sure if this is totally the right forum, but you guys obviously do a fair bit if bath install work.
At the w/e just finished the first step of new bath install. The bath is a plastic bath on a steel frame with feet that screw to the floor.
Screwed a batten against the wall to rest the edge of the bath on and have now sealed between the edge of the bath and the wall.
The plastic bath sides that came with the bath are not yet fitted so there's still a fair bit of movement when showering and moving around in the bath.
Anyway, had a shower this morning, and it creaks like hell along the batten on the wall. Had a look and I think the creaking is coming from the bottom of the lip of the bath rubbing along the wooden batten. I.e. when weight is put in the bath, the bath moves down a bit which causes the bath lip to rub on the wooden batten on the wall.
I think once the other sides are on the problem will get better, but you know what these plastic baths are like - they're never rock steady, so even when the sides are on I think it will still creak.
So the question is.. what to do? I think I could get a small amount of silicone in between the bottom of the bath lip and the wooden batten. Do you think this would help?
Cheers
Cheers
