Having a hot-tub wired in....
Hot tub is in rear garden, consumer unit is by front door..
Electrician has quoted £300 all in, which is...
Fit 32a MCB to spare way in Consumer unit (main switch has RCD built in)
Out of CU in 20mm conduit, out through wall, round side of house still in conduit with 4mm Twin and earth, down to a junction box where the cable will change to 4mm armoured with swa glands, then armoured will be run under decking for about 2.5 meters, then clipped to bottom of of wall for 2 mtrs, then into ip65 rotory isolator, don't know exact length of cable run but does not exceed 20 mtrs.
Just wanted to check, method and price really before I give the guy the job.
Any help would be appreciated.
