Hi there all, I have had this system for a few years and have been very happy with it, recently the original hard drive died and I decided to replace it with a larger HD, I have installed a 1TB Hitachi HD which was advertised as a drive specifically for CCTV application. I would expect that it is meant to run continuously without overheating. ( I am a PC tech so have a little knowledge on that side but not CCTV)
It has been working Ok but it does " hang" or " freeze" almost daily. The video channels just freeze and the date/time and camera labels disappear so it is just a blank still image from each camera. The only way to rectify is to unplug the unit and restart, I have noticed that if I leave it off long enough for the unit to cool down it works longer.
Is it something as simple as the unit overheating? And if so what would you suggest? The ventilation does not seem that great and the unit is getting hot on the Hard Drive section as well as the Motherboard/ Electronic side. I have vacuumed the ventilation holes, formatted the drive, set it to reboot daily, raised the unit off the surface so there is more airflow but to no avail.
Many thanks for reading and for any replies
