P pidgeon1 Joined 5 Jan 2010 Messages 671 Reaction score 49 Location Norfolk Country 21 Jan 2022 #1 I am unable to remove the hose from the machine, The coupling shows an arrow pointing down but this seems stuck ! 3 Quick coupling for high pressure hose Any ideas how I can release this.
Mottie Joined 27 Feb 2017 Messages 43,085 Reaction score 6,811 Location Essexshire Country 21 Jan 2022 #2 Got a picture? On my K7, I have to let the pressure out of the hose/gun to be able to use the quick release connector.
J just pumps Joined 24 May 2016 Messages 3,880 Reaction score 758 Country 21 Jan 2022 #3 pidgeon1 said: I am unable to remove the hose from the machine, The coupling shows an arrow pointing down but this seems stuck ! 3 Quick coupling for high pressure hose Any ideas how I can release this. Click to expand... On mine there is a tight plastic horse shoe clip that you remove by pushing upwards then pull the hose out.
P pidgeon1 Joined 5 Jan 2010 Messages 671 Reaction score 49 Location Norfolk Country 21 Jan 2022 #4 Mottie said: Got a picture? On my K7, I have to let the pressure out of the hose/gun to be able to use the quick release connector. Click to expand... Hose disconnected from tap, still stuck .
J just pumps Joined 24 May 2016 Messages 3,880 Reaction score 758 Country 21 Jan 2022 #5 pidgeon1 said: Hose disconnected from tap, still stuck . Click to expand... Push it in and twist it 90 degrees.
P pidgeon1 Joined 5 Jan 2010 Messages 671 Reaction score 49 Location Norfolk Country 21 Jan 2022 #6 just pumps said: On mine there is a tight plastic horse shoe clip that you remove by pushing upwards then pull the hose out. Click to expand... Just managed to remover hose, Think there must have been some crud in the connection hole, sprayed with GT 85.
