Washer Problems!
Kenmore 110.92587210 Stock 25872 s/n cf0128625
Unfortunatly Sears has no on line or customer assistance for troubleshooting problems.
Suspected bad part Timer 60HZ
part # 3946475
I checked all the obvious!
The plug, the socket and the switch, the circuit breaker.
115 vac is there!
The interlock switch (Lid Closed) works I tested with a ohm meter!
The a program is accurately selected!
No hoses are clogged!
All 5 or 6 the water levels work and fill the tub to the correct water level with no problem.
At this time the problem begins!
The agitating cycle begins but after about 30 seconds to about 1 minute it stops and then a minute later it will start again!
This will continue start then stop, start then stop until completing the full cycle and this continues thru all the cycles, (agitate, drain and spin) except the water fill cycle.
I can advance to the spin cycle and eventually after starting and stopping, and starting and stoping all the water will drain, but it is a very timely process.
Do you agree that the Timer is mot working properly?
Thanks for your heelp in advance,
Ken Meyer
Hicksville, NY
part # 3946475
115 vac is there!
Ken Meyer
Hicksville, NY
