You should not have done that as it was not "your" thread.
But you should have explained your problem here on your own thread!
This is what you had said!
I have a similar problem to this, although my jet engine takes off mainly when CH switches on first thing in the morning. It's just out of guarantee, so I'm loath to call someone out if it's a simple fix. I had someone called out a while back when it was making a noise and he said pressure was too low and lo and behold it got rid of noise. He also said there was some kind of bug in the chip and pressure reading could be 0.5 bar out! Since then I've always kept it up to about 1.7 bar, but I do have to frequently top it up. The other thing it does, which is pretty scary, is 'explode' sometimes when switching on for CH or water. Enough to make you stand back when you know it's coming on! This seems to happen when boiler temperature is low.
I'd be grateful if anyone can enlighten me on what's going on, via these questions:
1. If pressure is ok, what else could be causing the noise? I live in an area of quite high limescale, if this is the problem, what's the best way of cleaning it out?
2. Should I be concerned about regular topping up. On average about every couple of months.
3. What's causing those explosions?
Thanks in advance, Rob
