P
pipshady
Just after a bit of advice from any fellow engineers who have any experience with these boilers
long story short i have a customer with a suspected cracked heat exchanger on their celsius 25, now i have very little experience with kestons, i ve managed to avoid them up until now but i was just wondering if anyone else had come across one with a cracked H/E and wondered what the likely cause would be??
the reason i say 'suspected' cracked h/e is because i m going by what the keston tech line have told me, basically the boiler will not fire, gas and sparking present but when i removed the spark electrode i found them to be wet, i must admit i thought straight away that it was a cracked h/e as i had an ideal response 120 with same symptons before christmas!
so has any body else come across this problem? what are the heat exchangers like to change? and what is the likely cause of the h/e cracking
thanks in advance
phil
thanks in advance
phil
