Advice please. Have to replace an old (1994) keston and need a new std. condensing boiler, @22kW, with flue system as flexible as keston's, as it's to be located on an inside wall and will replace 2no. 40mm dia MUPVC flue/inlet pipes fitted between ceiling joists, running to outside, as used with old bolier.
Q1. is there a keston competitor that has equally flexible flue/inlet arrangement, using MUPVC or long reach concentric or separate flue/inlet (6m with 2no. 90deg vertical bends), as I can't find one on the net?
Q2. Any bad news so far about the relatively new keston qudos 28, following the extensive and well documented problems with Celsius 25s?
Thanks.
Thanks.
