We've had the kettle for a good few years and had no problems. However the other day I could smell a bit of an electrical smell in the kitchen I tracked this down to the plug on the kettle.
When I removed it, part of the plug had melted. The plug in question was a moulded plug.
It had melted around the top of the live pin. I was able to pull this out which came out along with the fuse and fuse holder.
If it was a fault with the kettle then I would have expected the fuse to blow before the plug melted. Although I am surprised that the MCB on the fusebox didn't blow.
From examining it, it appears that the fuse holder was riveted to the bottom on the live pin before being sealed inside the plug. The rivet felt loose and wobbly. I can only think that it had perhaps been arcing between the live pin and the fuse holder and generating heat that way?
Does that sound a plausible reason?
For now I have replaced the plug with a non-moulded plug and the kettle has continued to work perfectly. I have monitored the plug and the pin hasn't got warm at all.
Is it safe to leave like this now? I presume the original plug was at fault - perhaps it had come loose over the years from being plugged in and removed?
