I have a problem with a Worcester Highflow 400 RSF which my heating engineer is struggling to solve. To begin with the diverter valve went, replaced and solved the initial problem. Shortly after the system was producing a kettling sound when the hot water ran. Hot water was VERY hot and occasionally tripped the overheat even with thermostat set to minimum. CH working fine.
Firstly the thermostat was changed, no effect. The heat exchanger was then chaged - slightly surprisingly, no effect. Strangely it then worked for a little while although hot water was still very hot. Engineer could not explain why it started working.
Last night cold water started squirting from the diverter valve (heating engineer on holiday typically). We now have no hot water. Any ideas what the underlying problem might be?
