Citroen Relay 1.9d 2001 83000miles.
Van starts first time some days, but then about every 2 days or so I put the key into the ignition & turn on for glow plug warm up, but the key code light does not go out, turn to start engine starter operates but no firing. If I leave the motor & try it again later the light usually goes out & it starts. This problem seems to happen if the van has been run & switched off & on again after a short period. Also tried using the spare key with the same results. Any help please?
