The chuck on my dewalt Percussion has had it after 13 months with very little use. I have always had problems trying to tighten the chuck because the chuck key doesn't meet the teeth of the chuck very well.
Because of this the inside 3 bit clamps have wore away due the drill bits slipping.
Anyhow, I need to replace the chuck and I see I can get a keyless chuck instead of the keyed chuck.
What are your thoughts on what to get. The keyless chuck would be handy but I do wonder if there is a reason why Percussion drill come with a keyed chuck as standard. Is it to do with no being able to tighten large drill bits like 20mm etc but with the keyed chuck, you can tighten as tight as you can tighten.
Cheers for any advice you can offer.
