Quite foolishly (hindsight is great, isn't it!), I decided to take off the Aceenta G3 keypads so that I could paint the walls around them without it looking like I've just gone up to them and round them (I even take all the plugs and lightswitches off when decorating!).
Not a problem, I thought. As soon as the keypad is removed, it will enter tamper mode. Sure enough, it did. We have 2 keypads in the house, so I asked someone upstairs to type in the code and reset it. All fine.
Now I disconnected the downstairs keypad, and it appears the the upstairs one isn't lighting up (neither of the lights). So I reconnected the downstairs one and that's doing the same.
I went to the box and I put a multimeter across the 4 clear fuses that I can see. Didn't appear to be a problem there (do I have to take the fuses out to check them?)
Put the cover back on. The power light is on. There is voltage across the system if I check the +13v and there is also voltage going to the wires for the keypads (about 3v, I think).
What's strange is that neither of the keypads work now, but the strobe is constantly flashing.
The PIR's also appear to all be working properly (i.e. lighting up when movement is detected).
Can anyone help, please? Happy to try anything as I need this to work again!
Cheers.
Cheers.
