Hello,
I've got an ash tree that's around 10m tall and I plan to slowly cut down bit by bit next year. I'm a bit too busy at the moment and don't fancy doing it over the winter months, so plan to remove it in the spring. I had a lot of problems with cutting down a similar tree last year, and found it took ages and left me exhausted for days. I figure if it's dead, it will be easier and I won't have to try and kill it afterwards, as it is bound to be putting shoots up soon after. Better if the sap doesn't rise in the spring and make sawing the branches a lot easier.
I imagine I need to drill into it, so what would be the best kind of drill bit to use? Would an auger do it? How long/fat should it be? 300mm and 22mm wide? How about a flat spade bit? would that be better? Bearing in mind the wood is living and so is relatively wet inside the tree
What should I pour into any hole?
any advice would be appreciated.
