kinetico 2020c water softener
14 Jul 2009
London
I have a kinetico 2020c system and have switched from gravity fed system to a megaflow, does anyone know where i can get a conversion kit so that I can still keep the same kinetico water softener but use it with my new pressurised system? Has anyone done this before as I really want to avoid buying a whole new system as they are expensive! I'm not a plumber so where to go and who could help would be most appreciated if you have advise on that too! I'm in NW London
I assume that you are talking about high flow hoses? you should talk to the company that supplied your softener, or if not availible try Patmore softeners in Ipswich, they are kinetico agents ;)
Is that all I need to change, high flow hoses? Is there not any part inside the machine that also needs changing?
