Kingspan in timberframe..
27 Jan 2004
Insulating the timber kit walls with Kingspan 100mm thick, any advantage of running a bead of silicone where the kingspan does not quite touch the framing.
Most are a snug fit, but there are some touching in places and then slight gaps approx 2-3mm max in most cases.
Cheers
No advantage with silicone. Wedge some slivers of insulation in
I'll silicone some slithers in.. :p
Did use foam in one section..the old adage measure twice cut once :oops:
Thank you
