kingspan k3 floorboards.
26 Jun 2006
im about to start converting my garage which currently has a concrete floor.
if i was to use kingspan k3 floorboards, do i need to put a membrane down before/after and do i need to lay a chipboard floor on top, or just screed it?
thanks
Any insulation and flooring material you lay down will be governed by height tolerance up to the existing floor.
Kingspan sell a product called "Thermafloor" whereby the insulation is bonded to an 18mm chipboard sheet. A separate vapour control layer is not required.
http://www.insulateonline.com/
thanks for the reply noseall.
my garage floor is 130mm below the kitchen floor, i the largest k3 boards i can find are 80mm.
what do i do?
50mm of screed?
stack 50m of kingspan?
revert to standard joists with kingspan inbetween?
