We're replacing an old cast iron stack, but the ol' hole in the ground doesn't quite line up with the new plastic (plastic pipe mounts have different dims to the old CI ones and the invert is at an angle).
I've got a manifold aprox 400 above floor level servicing the utility.
What options are there to correct aprox. 50mm misalignment between plastic soil and the old concrete pipe in the floor?
Also, what are acceptable ways of sealing the plastic to concrete apart from using a rubber adapter? (Plumbers mate, mortar... etc)
Cheers,
Fubar.
Cheers,
Fubar.
