Hey, so I'm planning the kitchen (still) and I've come across a concern/issue.
I'm planning to run three units side by side along one wall, right up until the corner. And luckily enough I can fit two 600mm units and a 400mm unit.
Problem is, the corner where one of the units will need to have a complete section removed from the back as there's pipe work running vertically down the wall (boxed out). I understand that the service void is only 42mm and I'll need to allocate enough space for 65mm...
Apart from bringing all the units slightly forward (it's an L shape and will have a knock on effect with the other row of units), I'm guessing that I won't be able to cut out an extra 23mm from the back of the unit as it'll take away from the structure and fall over.
My other idea is to have a 300mm deep unit, but would rather avoid that.
Red line on the diagram shows how it cuts into the back of the 400mm unit.
http://img204.imageshack.us/img204/2699/kitchentb.jpg
