Kitchen base units off plumb - help please!
11 Oct 2013
Surrey
Hi, after spending some time levelling new kitchen base units to the same height and all level L-R and F-B, the sides are a little off plumb (spirit level and frame square confirm). What am I doing wrong here as it’s driving me potty? Howdens units with 4 adjustable legs.
Your help would be much appreciated.
Steve
Have you checked the units are actually rectangular rather than trapezoid? (Measure diagonals from opposite corners, bottom left-top right should equal bottom tight-top left. If they're not equal you need to square them up
Hi, thanks for the advice. I’ve measured one 600mm base unit and that appears to be out by 3.5mm between the 2 diagonals. Next question is how to square up, they are pre assembled units?
Thanks Steve
Wonder what tolerance Howdens work to- I'd be on the phone to them first off.
After that you need to have a look at how they're built and what keeps them square.
