I have found a number of variations on this problem. Here is mine as I have failed to find an answer.
I am installing 2 units. One 350 mm and one 300 mm on a wall. The wall is 785 from the corner to the window.
The board is dot and dab onto thermalite blocks.
The first 130 mm is mainly 5 cables I was unable to get moved.
There is a gap in the cables of approx 35mm.
My plan is:-
a) Cut out a little of the board to see if the hanging bracket can straddle the last cable where the gap is. (I am due some luck).
b) Something else.
I think these should be ok ?
https://www.locksonline.com/Cabinet-Hanger-Wall-Rail-2032mm-Long-6492.html
But what plugs to use.
The cabinets are wren infinity. (Big sticker saying must be screwed to wall through corner brackets). I guess I might need different hanging brackets if I have to use a rail.
My plan is:-
b) Something else.
