can anyone help. bought some new kitchen doors to replace old dated ones as nothing wrong with carcess. the problem ive got is one of the fittings to the cabinet is failing to hold i think basically because the hole is too big.
the doors are pre drilled for the hinge unit so no movement there but had to drill into carcess for that part of the hinge.
for the time being had to re hang the old door as the holes for that are fine.
i tried some special putty stuff from diy shop that is supposed to go hard enough to screw but didnt work has anyone got any suggestions as me and my dad are stumped.
only options i can think are to either:
1. hang the door from the opposite side.
2. find either a long screw or wider screw
3. drill all the way through to the next cabinet and use a nut and bolt.
unless anyone has experinece the same before and found a solution. cheers
