Kitchen cupboards on plasterboard with a cabinet hanger rail
17 Jul 2017
I am looking to install some kitchen cupboards on a wall with the following construction.
- Brick
- Vertical wooden battens (38mm x 63mm) laid flat at 400mm centres
- Battens fixed to the wall with four screws (5 x 80mm), 10cm from bottom and top, other two screws equally spaced
- 12.5mm plasterboard attached with drywall screws (Aquapanel used in the "backsplash" section of the wall)
The surface has not been finished yet, so I can make changes to the above, if needed but I am wondering if I can get away with just a single cabinet hanger rail (something like the one below), spanning the wall, and screwed into the battens.
Would that be sufficient, or would I need to get the screws all the way into the brick?
Any thoughts would be much appreciated.
Into the brick. Kitchen cabinets, fully loaded with cans, bottles and China, can weigh as much as you do
