K
kkynaston
I am in the process of sorting out my parents kitchen electrics
(with LABC involvement)
Need some advice please
The kitchen installer left the current set up 11 years ago:
Took out CCT (fed with 6mm) and put in 30Amp JB
Ran 2.5mm to 1 socket (over worktop), then to another (To supply gas ignition and fridge), then another (over worktop). The last socket on the leg has the double oven wired into it. Surprisingly enough you can't use both ovens at the same time!
What I am proposing to do:
Replace JB with DP cooker switch, then run 6mm from it to double oven.
Bring in new ring for 2 sockets + FCU and possible extension in future.
I was going to run the socket under the worktop for the gas igniter and the fridge from the FCU.
If this sounds good what size MCB should I use, 16, 20 or 32?
The 2 sockets over the worktop normaly have a kettle, toaster, fryer and microwave plugged in
Thanks in Advance
Kyle
Thanks in Advance
Kyle
