Help! I’m going to replace the kitchen ( wife) and need to re-do the wiring as I’ve found a spur from a spur situation. I‘ve also noticed that the kitchen is wired as part of the house ring-main. Knowing that it is best for the kitchen to have its own circuit; for practical reasons is it better to use a ring or a radial circuit? Currently it is wired with 2.5mm cable that I could extend/alter to form a ring; or I could create two radial circuits that would feed two halves of the kitchen. The second option is personally more appealing as it would for practical and aesthetic reasons mean not messing with the tiling (can’t see me find replacement tiles to match ) and knocking out too many channels in the plaster. As the wife has a penchant for doing everything in the kitchen at the same time, i.e. using cooker, washing machine, dryer, toaster, electric jug, microwave and the 'George Foreman' , would it be better to try to split the loading with the two radial circuits as opposed to the one ring? I understand that 2.5mm radial wiring has to be protected with a 20 amp rated MCBs and the ring would have a 32 amp. From a safety perspective which method would be more suitable particularly as I’ve worked out that if I went for the radial option the loading appliance wise (due to location) is imbalanced as it would be 1/3-2/3 – the 1/3 having a potential (everything running at once) current loading of 18 amps and the 2/3 of 33 amps at any one time. Can some bright spark please advise.
