Hi everyone.
Quite recently the extractor fan in my kitchen died so I went on to replace it. I removed it from the ceiling and I discovered that the canopy extractor fan outlet doesnt lead anywhere and instead just blows the air onto the ceiling (look at attached photos). No ducting whatsoever there.
I think when they build this place, they put a small extractor fan on top of the kitchen canopy extractor fan and the latter would blow the air into the other. This looks a bit strange to me. Also note that the smaller extractor fan on the ceiling doesnt have a ducting per se but instead blows air into the false ceiling and then this somehow finds its way through the kitchen ceiling, through the living room ceiling and outside the balcony grille. How weird.
Anyway, not much i can do there. So my question is this: I need to fix this situation. What would u advice me is the best thing to do?
A) Replace the small ceiling fan (its a standard 100mm fan thats operated by the kitchen light and independently from the canopy extractor fan)
or
B) do away with the ceiling extractor fan and instead install some flexible ducting from the canopy outlet to the already existing ceiling hole (look at photos). They are both 100mm.
What do you think? Which of the two solutions will be better in terms of extracting more moisture? Thank you in advance.
or
